Bikeboy57
Feb 10, 2021Explorer
Make up an air gauge screwed to a male disconnect. Put it in the fitting. If it is a aux brake system line it will not have pressure. Now press the brakes and see if you register pressure. You should see anywhere crom 30 to 90 psi depending on how firm your helper presses the pedal.
If you get pressure without pressing the brake pedal it is NOT an auxialliary brake line.
38,782 PostsLatest Activity: Sep 10, 2026
