CA_Traveler
Feb 11, 2021Explorer III
You might also want to consider using DOT approved air lines. While I'm aware that some use whatever hose, clamps and fittings this could be a libiality issue.
Also be aware that the Air Force 1 controller requires 3 lines. One is a supply line that fills the aux air tank. The second is the metered brake line that controls a valve to release the aux air tank air to the third line to the towed vehicle. This setup is required to meet federal guidelines.
38,782 PostsLatest Activity: Sep 10, 2026
