malmz's avatar
malmz
Experience Swapping Battery Control Center Board?
It is time...
I have had a replacement Battery Control Center Board for almost 6 months now waiting to get around installing it. RV is a 2001 Fleetwood Discovery Pusher with a Cat 330. The control board is a F73-1040 made by RV Custom Products, but only sold through Fleetwood.
The failure is that the coach would not switch automatically between house and coach batteries to recharge, and to prevent discharge. Also the battery cutover switch would not activate the solenoid. Diagnosis was the board.
Has anyone personally swapped on out? It looks pretty straight forward. I also queston whether I should replace the small solenoid that ocntrols the cut-over switch which is behind the board.
Finally, in the past I swapped the main large cutover battery solenoid to a Big Boy 200A and am wondering if the extra draw to kick may be too much for the board itself.
Steve
  • Changed mine also. Took a lot of pictures to be sure I could get everything back properly. Not very hard but was a real PITA. due to access (or lack of).
    On the draw of the 200A Big Boy - probably not an issue but I suggest calling Intellitec. When I changed mine I found I had a relay they did not document on the web site. Very frustrating.
  • There will be a little difference between the gas board & diesel board. The solonoids are larger and usually mounted outside the BCC box. IIRC it was actually easier to change out the diesel board due to that. Just take a few pics of the wires before you start and all should be well.
