burlmart
Jul 27, 2014Explorer
My concern is that a tour gets held up and you pup is alone longer than you planned.
I would feel better if dog could move around inside in case
campground power stopped or generator (generator is likely as reliable as campground power.
Know that a generator will shut off when gas tand gets to about 1/4 tank, so watch that.
You can likely run A/C with windows and vents cracked a bit and also run a 12v fan that will continue to run even if thw A/C power is disrupted.
Unless heat is extreme, the motorhome should not get nearly as hot as a car, so ensuring moving air and lots of water access, and not to long alone and should be OK.
I will admit we've skipped many a tourist side adventure because its value did not rise to the level of skipping out on being w/ our pups.
