soren
Jan 18, 2018Explorer
If I'm going to sit in one spot for a few weeks, I fill the frame tank just before I park it. I then treat this as back-up and emergency fuel. I install the extend-a-stay hose, and a 30LB cylinder. If it runs out in the middle of the night, I switch valves and run the on-board tank until morning, when I can refill the 30. At no point are both valves open at once, and I avoid using the frame tank as much as possible. At the end of a couple months long stay, the on-board tank still has quite a bit of propane. MrWizard probably does it better than me, by having two spare tanks, but I really don't have the room for any more tanks, so one works fine.
38,782 PostsLatest Activity: Sep 20, 2026
