kedanie's avatar
kedanie
Explorer II
Jun 10, 2013
Extend-A-stay
So, I thought that it might be a good idea to have one of the extend-a-stay valves installed on our coach. We have talked about some work camping and it would make things easier at least for the propane side of things.
Our coach has a center mounted propane tank that is behind a screwed on cover in the center of the main pass through storage compartment, not easy to get at. Camping World decided to install it between the manual shut off valve and electrical shut off valve. That seemed a little odd to me but went ahead anyway. They then mounted the tank supply line and fed it through the compartment panel.
It was about a week or so before we went back to pick up our coach and when I checked the compartment it stunk of propane. Turned out that the Extend-A-Stay manifold has a membrane check valve that is known to leak. The leak drained our entire propane tank into the compartment and now the compartment smells like propane. I am airing it out and with time i will get the smell out of the compartment. Apparently, the supply hose should be disconnected or attached to an external propane tank which ours wasn't.
We had them remove the valve and restore out system to the original configuration and refund our money.
Keith
