Dutch_12078 wrote:
kedanie wrote:
The only problem with this set-up, at least in my application, is that I would have to empty the bay, crawl inside, remove a panel and then shut off the main tank if I wanted to use an external tank. If you can't shut off the main tank, you would be drawing from both tanks until they were both empty. That doesn't seem to be a very smart option in my application.
How do you shut off the tank service valve to refill the tank?
The tank has a manual shut off valve and next in line is an electrical shut off valve. Flip the switch and the tank is shut off. CW tried to install the Extend-A-Stay valve between the 2 shut off valves. The tank fill port is on the side of the coach.
Keith
