wa8yxm
Jan 19, 2018Explorer III
Dale.Traveling wrote:
Don't see a problem but the big question,except which tank will be consumed first? Main, portable or will both run out at the same time?
It is impossible (with both tanks open) to tell which one is supplying gas till they run out.. So long as either tannk has gas in it you will have full pressure both sides of the regulator. pressure is NOT dependent on how much gas is in the tank, any amount, even a couple of ounces of liquid will give you full tank pressure.
So close one tank (The AUX would be my suggestion) till the main runs dry or close the main and when the aux runs dry haul ti to the refiller and run on main.
38,782 PostsLatest Activity: Sep 21, 2026
