ernrays
Sep 01, 2013Explorer
Extended Stay Propane Tanks and Furance Problems
I own a Winnebago Sightseer (2002). Love it. However, I didn't love driving it 30 miles to fill up the main propane tank so I installed an extended stay propane tank (20 lbs) system. Both the main tank and the 20 lb tank feed into a common regulator. At first it seemed the addition was working fine (2800 feet above sea level). I then took my rig to about 9800 feet elevation and experienced a problem with the furance. It would work normally (cycle on and shut off normally) when on the main tank but failed to light when I would use the 20 lb tank. So, I replaced the regulator (same model number) and bought a new 20 lb tank. The problem is still there (i.e., the furance won't light when on the 20lb tank). The water heater works fine; so does the frig/freezer and the stove. The only problem I have is the furance.
I suspect that when the furnance tries to turn on, the propane flow increases so rapidly that the safety flow valve in the 20 lb tank closes. If so, I don't know if there is a solution to my problem outside of using the main tank at night when the furnance is needed. Does anyone have a solution so I can run all of the appliances off of the 20 lb tank, including the furance? I'd rather be fishing than breaking camp to fill up the main propane tank. Thx.
