snoopeme's avatar
snoopeme
Exterior Trimark RV Lock failure
I have a 2014 Leisure Unity and the exterior lock failed recently? It is the regular latch not the deadbolt which doesn't fully retract and keeps the door from opening. It has a Trimark #060-1650 lock on it which is available at Camping World for about a hundred bucks. A little Internet searching reveals many complaints about the Trimark locks, and I'm thinking that they did a re-design with this model being the latest version. From what I can tell I think I may have the latest version, but this rig is only 3 years old and I only use it a couple of months a year..so why would it fail already? I did open up the lock and found a small, white plastic piece which seemed to be the problem as it sometimes keeps the throw bolt from working properly. Does anyone have any experiences with this problem, with the Trimark replacement locks from Camping World, and from their so called re-design? Is this new re-design any better? Thanks for any guidance you can provide! Also, is anyone aware of any other brand of replacement lock that would fit without any modifications? I've emailed LTV recently about the problem and am waiting to hear back from them. Any comments on your own experiences would be appreciated.
  • our 2016 Outlaw trimark door handle broke this summer luckily we had the back opened up and could get in off the deck . Poor design for sure got another one so we will see what happens
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I had that same issue with the Snap Bolt on the Tri-mark... They use very cheap metal and the high stress point is the weakest point on the dead bolt so it breaks and won't retract at all...
    or the screw in the pivot comes loose and the arm that retracts it comes loose
    Either way.. If the screw loose and you can get it apart.. you are good.
    If the bolt.. Then using a curved rod you may be able to depress the plunger and release it.. I did it once, had to have a pro do it the 2nd time
    1st time I put in a new lock
    2nd Time I had a metal smith carve me a new bolt out of genuine Steel
    Has yet to break,, but it has only been in there for about a year .
  • I've had great luck dealing with H.E. Mitchell when looking for anything to do with MOHO locks:
    Motorhome Locks
    Lou
    05 Travel Supreme Envoy
  • I replace ours some six years ago. Also Trimark. Mine was worn out inside and I just call them and they sent me a new one that was not very much. I have since found different one on the Web that were a little less.
  • Try locks and more dot com. I replaces my trimark after it desinagrated. lucky had a window open and could gain access to the trailer I could lock the deadbolt from inside and lock it as well we were in a safe place so no problem waiting for a delivery for new lock.
  • After 13 years my deadbolt Got stuck in the locked position, I was outside. I drilled out the old lock unit and bought a new one on line, not from Camping World. Don't remember the cost but it was an easy removal and install. I called Trimark for the drill sites.
