jtadExplorerJul 06, 2016External brake on slide out motor ?Can someone tell me how the external brake on my power gear slide out motor works? It had the little handle at the end of the motor..
rgatijnet1Explorer IIIJul 06, 2016If your slide has two motors, you have to switch from one to the other as you manually crank the slide in, to keep it even.
Related ContentSlide Brake ProblemSurge or electric brakesEasy way to remove slide topper?No brake or external lightsarctic fox slide adjustment
