Goldencrazy wrote:
Yes, I get park cable on both tv's with antenna booster off. I get jack antenna on both tv's and I get satellite signal from rooftop dish on both tv's with separate receivers. I am just assuming the external satellite port is a direct coax to the outlet in overhead compartment and it can't be split without a powered multi-switch and they haven't done that as I have only one coax outlet in bedroom and that handles roof top sat, cable and ota.
Have you tired putting a splitter at the location where your rooftop dish coax is? in other words, combine the two coax cables with a splitter so that instead of JUST the rooftop Satellite antenna feeding the two boxes, both the rooftop and/or the remote satellite antenna are feeding both satellite boxes. This should be able to be done in the overhead compartment.
