awesomeman
Mar 14, 2018Explorer
extra propane capacity
Hi everyone I have a 22M Minnie winnie that I absolutely love. The only issue I run into is on extended stays you can start using up a lot of propane. Between the heater and water heater, we go through it pretty quick. I have been doing some research on the adapters to utilize an additional tank(like a bbq tank) in case you run out. Are these safe to run. If so can you please recommend a particular kit. I dont mind the cost, I just dont want leaks or to run out of LP.
Thanks!
OR
Maybe even better is it possible to stuff a larger propane tank as a replacement.
Thanks!
OR
