dodge_guy
Aug 29, 2020Explorer II
crawford wrote:
Ford built the truck frame and suspension why should any place change specs? Adding extra better shocks and better heaver sway bars front and read but that will not change it.
Because Ford built it as a universal chassis. For everything from a small 10k lb bread truck to a 40 foot 24k lb MH. So you can see how these things need to be adjusted to an as needed use. More caster will make it track straight down the road. Toe in is the only thing the needs to be adheard to.
38,783 PostsLatest Activity: Sep 23, 2026
