RLS7201
Aug 29, 2020Explorer II
crawford wrote:
Ford built the truck frame and suspension why should any place change specs?
First off the F53 is NOT a truck frame. It is built for motor home application. The equivalent frame for trucks is a F59.
There are various sources for the F53 front end specifications, but the latest specs seems to be toe-in of 0.06 deg toe in, plus/minus 0.25 degree.
Plus or minus 0.25 degrees would allow for some toe-out or too much toe-in. Thus the Family of F53 Ford owners have found that a strong toe-in setting (0.14 degrees or 5/32") is the best for handling and tire wear. Now you know.
Richard
38,783 PostsLatest Activity: Sep 23, 2026
