JDsdogs
Jul 27, 2019Nomad II
F-53 Axle vent
A couple of years ago, I was traveling with my F-53 Chassis, class A Motor Home when I notice the smell of gear oil. Checked the rear axle and the inside of both inner rear rims were covered in gear ...
JDsdogs wrote:It is if you are following the Ford service book, unless of course you have memorized their specs.
I can only figure that the suggested the torque wrench is for properly tightening the lug nuts? One is not of much use to set up the wheel bearings.
