I just pulled the trigger on a 35F Itasca. I know the mod on the front sway bar, do you have to get or make longer links?? Where can I find plans on making a trac bar? Does loading the back heavy help...
Some get helwig adjustable links and install them. Some just use the same links. Your choice. I installed the adjustable links. Trak bar connects rear differential to frame. Pricey item but worth it. In addition to mod CHF I added Roadmaster rear anti sway bar and Steer Safe on steering. Works for me.
