I just pulled the trigger on a 35F Itasca. I know the mod on the front sway bar, do you have to get or make longer links?? Where can I find plans on making a trac bar? Does loading the back heavy help...
I made my own rear trac bar for $80.00. Took some bolts out of the rear end and made a template. Took it to a metal shop and they cut it out and drilled the holes. I used 1/4 steel. I found a bracket that worked at the big truck shop when I had a alignment done. For the bar, I went to tractor supply.
