blknomad
Aug 23, 2013Explorer
F-53 chassis
I just pulled the trigger on a 35F Itasca. I know the mod on the front sway bar, do you have to get or make longer links?? Where can I find plans on making a trac bar? Does loading the back heavy help...
Edward 75 wrote:
Do you have to jack the motor home up or can you change the sway bar holes without jacking it up. Would like to change front and see if it helps any at all and then maybe do the rear. Thanks Joe
