nickmaeExplorerApr 05, 2014f-53 fuel pump pressureDoes anyone know what the correct fuel pressure should be for a 96 class A efi 8 cyl.engine? I'm only getting 20 lbs max. Looks like I need a new fuel pump. Thanks
allbrandautoExplorerApr 06, 2014fuel pressure is 35-45 psi. key on engine off 30-40 psi. engine running
Related ContentF-53 tiresF-53 V-10 Oil CapacityF 53 alignment & steer safe2022 Tiffin - F-53 Chassis - BrakesF-53 Sway Bar Adjustment
