time2roll
Sep 09, 2017Nomad
Coffee Grinder wrote:How fast were you going and what rpm?
Recently was in Colorado and had a couple issues gearing down low enough to be comfortable. Used "Tow Haul" and worked pretty good then tried gearing down to lowest gear on shifter which didn't seem to do as well. Most issue was Wolf Creek Pass . Any advice would be helpful. Thanks
Transmission will not shift into low gear unless you are going slow enough to avoid over speed on the motor.
38,774 PostsLatest Activity: Apr 26, 2026
