allbrandauto wrote:
you don't need special tool for seals I think your working with a floater rear wheel bearing don't have to be packed with grease fluid from rear lubes bearings when you put hubs on go in as strait as you can so as not to damaged seals make sure you top off differenchal fluid
I decided to skip the rear bearing, because I wasn't sure I could remove the seal without damaging the bearing (I think when I have more time I 'll remove it and redo it). Now I have the axle back in and ready to put the caliper on.. then the next side ... fun
