Chum_lee
Mar 04, 2020Explorer
MetalGator wrote:Chum lee wrote:
Only use the specified brake fluid if you need to top off. (see your owners manual or the reservoir on the MC)
Chum lee
I would think you would need some type of pump to fill the bin. The master cylinder is high up in the compartment and right under the dashboard. Barely enough room to take the cap off.
I will report back once I get the motorhome back and talk to the service writer. He did tell me this was covered by the Ford warranty.
Yes, it is tough to add brake fluid on the F53. You'll need some type of siphon or pump. A turkey baster (filled with brake fluid) with a flexible clear plastic hose on the end will work in a pinch. Or you could try using an old (empty and well cleaned) hand sanitizer bottle with pump. IMO, don't use the baster in the kitchen again unless you clean it really well, . . . . . . . and, . . . . . don't tell anyone else. Make sure the Ford Dealer tops the reservoir off with new fluid before you leave the shop.
Chum lee
