johnhicks
Mar 04, 2020Explorer II
When a master cylinder has an external leak it'll leak between the cylinder and the hydroboost; that's why there's a weep hole there so if either leaks it won't contaminate the other.
The solution of course is to replace the master cylinder. Then I'd completely drain and refill the brake system since you'll be seriously bleeding it anyway.
It's a failure, no way normal wear and tear.
Spray everything with VHT rust converter or paint with ospho.
38,782 PostsLatest Activity: Sep 10, 2026
