rich82333
Oct 12, 2016Explorer
f53 chassy
I have a 2017 thor ace 29.4 with a f53 chassy. I want to put sway bars on front and rear but nobody can tell me if the f53 chassy has changed. no body has listing for 2017 sway bars
RedRollingRoadblock wrote:
Like ductape said. Do a search for Cheap Handling Fix. You will find lots including some You Tube videos. Or go to http://www.irv2.com/forums/f23/cheap-handling-fix-72335.html and spend three hours reading.
Park your MH level and have a the proper tools. IIRC a 17mm, 19mm and a 13mm(?). You likely won't need to raise vehicle. Loosen the down links at the sway bar. If you can't raise the bar to line up the holes or it is too hard to raise loosen the bushing mounts a little. CAUTION the bar could drop. Refasten the down links to the inter hole. ( To the rear if doing front bar, to the front when doing the rear.) Put some blue Locktite on the bolts, tighten and enjoy your new ride.
