rich82333
Oct 12, 2016Explorer
f53 chassy
I have a 2017 thor ace 29.4 with a f53 chassy. I want to put sway bars on front and rear but nobody can tell me if the f53 chassy has changed. no body has listing for 2017 sway bars
rgatijnet1 wrote:
My neighbor has a Class A with the F53 chassis and other than the CHF, the only thing he felt it needed was a steering stabilizer. He doesn't see the need for a beefier anti-sway bar, track bars, or any other suspension mods.
Have you had your coach weighed and are sure you are running at the correct inflation pressure or a LITTLE above and that your front axle is not loaded too light? A lightly load front axle will tend to make the rig wander.
When you have it weighed, make sure it is completely loaded, full fuel, water in the fresh water tank and all occupants are in their seats.
