I put Monroe RV shocks on ours and am happy with them. The sway bar bushings probably need to be replaced, no longer available from Ford, but are available on eBay. The brake fluid should be flushed. If you don't have maintenance records, I would change transmission fluid and anti freeze. It's easy to check the brake pads, mine were still in good shape at 50,000 miles.
