MitchF150
Aug 08, 2023Nomad
If it's the first time to replace the filter, it could just be that the locks are stuck.. Spray some WD40 or your favorite penetrating spray on the ends to flush out the lock. Might need to do this several times to get any dirt out of there too.
Then insert the tool and get some needle nose pliers to help push it in at the same time pulling on the hose until it releases.
I had a 97 F150 with that style of fuel filter and I used the 'scissor' tool.
It was a PITA to do every time! Then you get all the gas that spills out when you finally get it off! :) So be prepared for that.
Good luck! Mitch
Good luck! Mitch
