SixRRanchExplorerFeb 13, 2018F53 Output Shaft Assembly failureExtreme vibration suddenly set in with a ferocious roar at speeds above 45mph while traveling down I-95 South. Discovered five of seven bolts were out of the emergency brake assembly at the transmiss...Show More
Related ContentRam Cummins/Aisin FailuresWheel hub assembly failure due to towing?Jack Failure DisasterGenerator output voltageWater Pump Failure Traveling To The Eclipse
