Sastma
Jun 12, 2021Explorer
[img]
[/img]
Cause we all like pictures…
[img]
[/img]
What ended up doing was put the brackets in a vice to add more compression around the bushing. It did make a tighter fit.
[img]
[/img]
When pulled the brackets I noticed the bolts were quite loose. Thinking the brackets might have spread out do to the loose bolts.
The whole thing seems like a hodgepodge fix by the PO.
And now I just added to it :)
I’ll get the proper parts.
[/img]Cause we all like pictures…
[img]
[/img]What ended up doing was put the brackets in a vice to add more compression around the bushing. It did make a tighter fit.
[img]
[/img]When pulled the brackets I noticed the bolts were quite loose. Thinking the brackets might have spread out do to the loose bolts.
38,782 PostsLatest Activity: Sep 01, 2026
