rjstractor
Aug 29, 2021Nomad
pianotuna wrote:
Wheel base to length is fairly critical for good driving characteristics. The ideal ratio is 55%. On a class C that is filled by the 176" wheel base on a 26 foot body. Mine felt as if I were driving a large car.
As the body gets longer the drive becomes worse and worse. Tail swing rises dramatically. When I moved to a 28'5" driving became worse, and I had 5 tail swing incidents. I had replaced the rear bumper so there was little damage to my unit.
The possibilities on the F 53 appear to be 138", 158", 168", 176", 178", 190", 208", 228", 242", 252"
What ever maker you go to make sure to be close to the 55%, as you said, this is your last kick at the can, and you have already had one unruly motorhome.
Good points. The OP is looking at Class C motorhomes built on the F550, not the F53 which is used for Class As. I looked at the Thor Cs (which I know the OP doesn't want) and they were all over 55% The largest one (actually built on the F600) has a 267" wheelbase! The heavy diesel engine up front helps too.
38,782 PostsLatest Activity: Sep 10, 2026
