dougrainer
May 17, 2016Nomad
eHoefler wrote:
Convert them to the Barkley electric valves. I did mine 2 years ago, they work flawlessly. Only cost $20 more than the cable replacement.
Until they fail and then what do you do?. Cable Valves are used where there is usually NO access to the valves or they are in a enclosed underbelly. They make extension rods for the manual pull valves. IF the OP has room, he can replace with Manual pull valves and install the correct extension rod to get out the needed pull area for the handle. Also, if they fail that often, it may be how the cable is routed. Making sure you have NO tight bends makes a big difference on operation and longevity. Doug
38,782 PostsLatest Activity: Sep 10, 2026
