Jackie_Treehorn
May 17, 2016Explorer
Now after looking up into the way it's set up there's no way to manually open either valve- the action in each case goes towards the other so the only options appear to be replacing the cables or going electric which there appears to be room for. The bad thing there is the manual override on the electric would not be able to be used. The bend in the cables are dramatic and the gray especially so- maybe there could be a rerouting since right now it's about 200 degrees in a really short span. It's definitely poor engineering.
38,782 PostsLatest Activity: Sep 10, 2026
