wa8yxm
Sep 16, 2014Explorer III
Dang, I thought I had big hands.
If you can not get to the stems to check the pressure you need to have a tire professional fix that for you.
There are two ways..
Many use Valve Stem extensions, These come in flexible and rigid types. The Rigid type is likely better, but....
Dually stems is a company that makes valve stem replacements, This requires a tire man remove the tire and replace the stem. They extend out through the simulators (Liners) and make it easy to check the pressure.
You can also use some varaities of tire pressure monitors that report the pressure.
38,769 PostsLatest Activity: Apr 03, 2026
