dufferdj
Dec 27, 2017Explorer
False alarm w/ Safe-T-Alert CO/Propane Detector
A couple of years ago we had a chipmunk or ground squirrel find it's way into the RV, specifically under the refrigerator. After plugging his entry and cleaning his/her droppings out from that area I sprayed with Lysol. Apparently that was not a good idea. Since that time I've had a series of problems with the Safe-T-Alert CO/propane detector giving false alerts. Prior to coming to this conclusion I've sent 2 back to the manufacturer and they have sent me replacements, but this last time they returned the same unit and said that there was nothing wrong with the unit. That's when I thought that it might be some leftover fumes from the Lysol. Even though I have repeatedly washed out the area with water, and it has been a couple years since spraying, after a few nights in the RV it starts to beep. Between trips I remove the detector and move it well away from the wall mount under the frig. In the meantime I use a portable CO detector. Any suggestions as to what I might do to rectify this problem? Thanks.
