jstaffon's avatar
jstaffon
Bad Safe-T-Alert CO/LP detector
I'm hoping I can get some help from others who have had the same or similar problem. My 2016 Rockwood came with a Safe-T-Alert CO/LP detector located just inside the entry door near the floor. We were dry camping in the mountains of Idaho on its maiden voyage last year and around 3am, I hear this ear piercing beep coming from the downstairs area of my 5th wheel. After some investigating and testing, I found out my batteries were at around 11.3 volts and the CO/LP detector was in a "Failed" state due to low voltage. The solution that evening was to start my generator and let it run all night. The next evening, same thing happened. Needless to say, we cut our trip short and took the trailer back to Camping World to have them check things out. The batteries were tested (ok) and the CO/LP detector was tested to make sure it would sense CO and LP (ok). The low voltage issue I complained about was not checked. Long story short...we've replaced the unit 3 times over the course of several months and still have the same issue. According to the documentation and Safe-T-Alert's Support personnel, the detector is supposed to issue a low voltage alarm at 10 volts and a failure alarm at 7 volts. I'm getting the failure alarm at 11.3 volts. Oddly enough, if I put the detector on the variable voltage supply, it will alarm at 11.3 volts and recover at 11.5 volts. Safe-T-Alert doesn't seem to be interested in fixing the issue. Their solution is to send another unit in hopes of finding one that works as documented. My concern is that there are 100s or 1000s of campers out there with faulty CO/LP detectors. If it doesn't operate as documented, how can you be certain it will save your life if CO ends up in your camper. Right now, I'm operating with a portable CO detector in my bedroom area and I have the Safe-T-Alert unit disconnected. Has anyone else had the same problem or similar and are there any solutions. This has been going on for a year now and can't seem to get anyone to act. I would like to find something permanent instead of using portable detectors. Thanks in advance!
