murraymcleodExplorerMar 05, 2016Fan blower only works on high speed....I have the Itasca detailed below, and lately has developed an issue where the dash fan will only work on the high (noisy!) switch setting. After starting the engine (Chevy workhorse 8.1 engine chassis...Show More
azrvingExplorerMar 05, 2016x2 on the resistor. Older ones had a resistor type coil. I have repaired some newer styles that melted the solder strip connectors.
Related ContentNot all Aftermarket bumpers workCordless blowersSpeed limitsA/C blower motor question..Towing Speeds
