murraymcleod
Mar 06, 2016Explorer
The thermistor is the resistor like thing below the coil? And that's a high temp cut-off or something? It seemed as though, from my voltage test, that current was passing through this assembly ok regardless of where the switch was set, but does that mean the fan should be powered in these situations?
So you would recommend replacing this resistor assembly first, as it looks suspect?
38,769 PostsLatest Activity: Apr 03, 2026
