murraymcleod
Mar 07, 2016Explorer
fourmat wrote:
with your fan switch in the lower settings do you have 12V to the resistor if you do then replace the resistor if you don't then it is the fan switch or wiring.
The fan switch seemed to provide 12v to the resistors no matter which setting it was on. I think I'll just replace the resistor assembly first as they are not that expensive ($12 vs $40 for the switch!). The black spot on the switch did NOT appear to be a burned area, but just grease or some fastening material.
Thanks to all for the help....I'll let you know the outcome!
38,769 PostsLatest Activity: Mar 31, 2026
