AstroRig57
Mar 19, 2016Explorer
Incredibly enough, and this may sound counter-intuitive, but I had a bad ground where it connects into the blower motor behave in the same manner. I trouble shot the system all the way from the resistor, to the relay, to the switch with no definitive diagnosis.
The next step was to backprobe from the motor. I removed the panel/vent assembly from the passengers side to get to the motor, and since it happened to be after dark, I noticed arcing as the motor cut in and out, low to high... The motor ground was held on only with a small sheet metal screw mounted to the motor/blower chassis. When I tightened the screw everything worked properly...and at all speeds. After a few off/on cycles, the blower motor stopped working or would work only on high. The screw had so few threads in contact that it had backed itself out and would not tighten. I speculate that it would sometimes work on high only because the higher voltage bridged the gap at the bad ground contact. (thus the arcing)
I removed the blower/motor assembly, filed the paint from the area around where the ground screw mounted, and installed a bolt with a lock washer and nut into the hole. When I reassembled the blower/motor assembly I attached the ground to the bolt with a lock washer and nut. I have not had an issue since.
38,769 PostsLatest Activity: Mar 31, 2026
