Executive45
Apr 28, 2015Explorer III
1. High idle. Do you have a "smart wheel"..? Cruise control must be ON. Flip switch, use set and resume to increase or decrease idle.
2. Dumping air. If the engine is running, air is being replenished into the system, so dumping while refilling would be counterproductive. Yes, the engine must be off and key on to dump the air.
3. 12VDC disconnect switch. Are you referring to the salesman switch by the door? Most of us have bypassed that switch as it can be inadvertently bumped going out of or into the coach. Yours most likely has been bypassed also....Dennis
