msmith1199 wrote:
dougrainer wrote:
msmith1199 wrote:
So basically what I said????
No, the glue did not fail. The air intruding under the Rubber caused the rubber to pull loose. BIG difference. HOW do you think we remove the old rubber when we replace the Roof?????? Doug
You blow on it?
People like you we fire as customers. You are not worth the BS you bring. To answer your STUPID response--you cut in strips and PULL it off the decking. It takes a LOT of strength to rip those small strips OFF a correctly glued roof. So, this shows the force of wind at 60 mph getting under the Rubber and pulling it loose to bubble. To also answer your stupid response, if glue failed why do you not see bubbling at the middle or rear of a rubber roof in transit? Because there is no place for the wind to get under at those spots. Doug
