two_travelersExplorerFeb 16, 2017Figuring the correct tire pressureRecently had our coach weighed. We are at 6,700 lbs (3350 per tire) front and 12,180 lbs (3350 per tire) rear when fully loaded. Tires are Goodyear G670. Using the tire pressure chart from Goodyear it...Show More
wildtoadExplorer IIFeb 16, 2017Set them at 80 and see if you like the ride. Based on your info 80 will support more than you weigh.
Related ContentCorrect tire pressureCorrect Tire Pressurecorrect air pressureCorrect tire pressurescorrect tire pressure
