Jim_Norman
Feb 17, 2017Explorer
Just right is what you really want, however it is difficult to obtain. You need a 4 corner weigh, then set your pressures to the heavier corner for the front and for the rear. Under inflation is a killer, in many ways. Tires overheat, sidewalls flex way beyond design, handling downgrades and ride can worsen. Now over inflating has its own issues, hard ride, odd tread wear among others.
So get weighed with your rig as full as you use it, not empty. Get each corner weighed and then do the research. And when you are done, remember tire pressure is not a constant! Monitor it! If you inflate in June, you will not be correct in December! Check you tire pressure each trip, or possibly get a TPMS system and set it up. It could save more than a flat tire.
