gonervn501
Dec 22, 2015Explorer
Filling Batteries
I'm looking at the Flow-Rite Pro-Fill battery watering system for my Allegro. From what I have seen they seem to work well. Does anyone have thoughts on these?
Canadian Rainbirds wrote:jwmII wrote:
A lotta to do over nothing. Just another gimmick and expense. How hard is it, really to check the water level in a battery ? It takes so little time and allows you to check for other potential problems in the battery drawers (boxes) or whatever. Things like loose or broken wiring at the battery terminals, corrosion, etc.
Yeah, right. On ours, checking the first two isn't too bad, but the bedroom slide has to be in to access the batteries.
For the other two:
Remove the negative cable(s)
Remove all cables from the first two.
Remove the first two batteries (at 66 pounds each)
Slide the rear two forward, which can only be done about an inch at at time, until they are fully forward.
Now the vent caps are accessible.
Check and fill as required.
Reverse the above process.
I only do this twice a year to check the SG and check and clean all the connections unless something leads me to believe that there may be a problem.
