turbojimmy
Sep 22, 2014Explorer
There's not much to cover that everyone else hasn't except to emphasize that you need to fix your 12V problem before you try to troubleshoot any further. I have an '84 Allegro and learned early on that:
1) Power converters of that vintage suck
2) Power converters of that vintage suck even more when you are using it to charge batteries that have deteriorated beyond charging
I replaced my power converter with a modern unit with a smart-charging algorithm and 2, new 12V deep cycle batteries. The difference is like night and day - everything started working properly.
With regard to your generator, I would try the Seafoam first. If that doesn't work try the more aggressive carb disassembly and cleaning. Mine ran okay, but surged under a load. Seafoam made a world of difference. My experience with engines that sit, however, has been that if you need to choke them to keep them running then you have a blockage somewhere - probably in the jet that someone else mentioned. The problem is that there isn't enough fuel for the engine to run with the unchoked airflow.
