empty_nest's avatar
empty_nest
Finished with a couple upgrades
Just finished changing out the front analog TV with a 32" HDTV. Got some ideas off these forums and YouTube and went for it. I know I'm not the first one to have ever done this, but I'm pretty satisfied with the way it turned out.
Also installed a new CB radio and antenna. We'll take it all out for a test run later this month.
  • Executive wrote:
    Busskipper wrote:
    What's a CB - a new App for the Phone?
    :B
    :S
    A CB is that thing that actually WORKS when you have ZERO cell service, which is pretty much all along the west coast thru Oregon and Washington. :) ...Dennis
    From what I understand, that is also the case for a lot of the AlCan. We hope to make that trek in 2019.
    :B
    :S
  • 2oldman wrote:
    Hosted on irv2
    Roger that, I'm in the process of removing all of what I have on P/B and installing all of it in a file. Then I'll transfer a bit at a time, to IRV2. Thanks for the info.
    Scott
  • FIRE UP wrote:
    May I ask, what did you do to make the pictures come through?
    Scott
    Just uploaded it somewhere else and then linked it.
  • May I ask, what did you do to make the pictures come through?
    Scott
    Empty nest,
    Your images did not come through. I see you're using the infamous "Photobucket". Well, just in case you didn't "get the memo", Photobucket has ceased hosting photos FOR FREE!!!!!!!!!! If you want to continue to use them, it's going to cost you around $300 a year or so. I really wanted to see how yours turned out 'cause I just finished changing out our boat anchor Sony too. I also did a complete sound system change to a better receiver and more. It is great. But, I'd really like to see yours.
    Scott
    Thanks! I realized it after I posted. Made some changes and the pics are now visible.
    Empty nest,
    Scott
    On edit: OK, I'm all screwed up. After I posted this post, when it came up, your pictures are THERE! Hmmmmm, not sure what's happening. But, I do see yours now, nice work.
    Scott
