Mocoondo
May 16, 2013Explorer II
RvnStreib wrote:
This is my first time posting and I need help.
I have on 03 4winds 31p class c MH ,2 years ago I purchased 7 new off brand tires (Mastercraft) I have now had 3 damaged tires in the inside pass. rear The tire dose not go flat it delaminates part of it. What to do now
1. larger load range tire
2. name brand tire
3. check for any thing causing damage to tire. (breaks replaced May 03)
Specs.
I am over weight
frt. axle 3780 lb - rv rate 4600 lb
rear axel 10300 lb - rv rate 9450 lb
trailer axel 5720 lb - trailer rate 7000 lb
So, to recap, you are running on cheap tires while overweight and towing a 7,000# trailer.
First, I would make sure that you do not have any specific problem with the RRI position. For example, a grabbing brake, wheel bearing issue, axle problem, etc., since it is indeed a little strange to have three tires in the same position let go in the same fashion in two years.
Second, get a set of quality tires with the proper load rating.
And third, you should really have a solid heart to heart conversation with yourself, analyzing your operation, and deciding whether what you are doing is the safest course of action for both yourself and other people on the road. I don't believe that a 30' Fourwinds has that amount of towing capacity. Running that far overweight on garbage tires is a very risky proposition. I think you are very lucky to have only had a couple token blowouts. Consider those "warning shots" that something is seriously wrong.
38,709 PostsLatest Activity: Mar 08, 2025
