Go_Dawgs1
May 16, 2013Explorer
I agree with above posts. You are overwieght and under pressure on tires. I have an 03 Chateau 26' and I have a class III hitch rated for 5000# which is max for the 3500 GM chassis. I have my tires at 70 lbs front and 80 on the rear with is max for the duals.
You are 1000lbs over weight on the rears and running way low on pressure. Trying to pull 7000lbs so drop a grand on your loaded weight, drop 2K on the trailer and buy some good tires.
38,706 PostsLatest Activity: Feb 03, 2025
