JeffCarol's avatar
JeffCarol
First time used buyer, any specific advice js appreciated!
Hello all, I am a retired helicopter mechanic from the USMC. I say this hoping a maintenance background will be useful as I am looking to buy a 1995 Safari Ivory, 300 HP Cummins.
The coach seems very well maintained with new tires and brakes all around. Everything is functional and I see no evidence of Mickey Mouse maintenance.
I am new to RVing so I have been voraciously reading everything I can find regarding inspection and maintenance.
It seems like we are buying an antique compared to most of the coaches many of you are discussing but we need to stay in our pay grade. Is there any specific areas to scrutinize that only experience would teach.
Please share some wisdom if you will folks!
  • Treat it just like a copter you've never seen before and have just been told to make it airworthy.
    In one of that vintage you need to crawl under with a flashlight look for unusal wear of everything, bright metal usually trouble underneath. I would check as much of frame as possible looking for any signs of damage, cracking or especially of past repairs. The outside front to back top to bottom. Look for proper roof maintenence, seals around any protrusions through the exterior skin.
    Propane storage and delivery to points of use. Hugh safety issue. A cracked propane line is not good, I traced all mine visually as much as possible before I bought.
    Interior others have addressed, make sure everything works, spend a day in it, pull all draws out and look behind for evidence of past structural repairs also.
    Remember, if you can't find anything wrong; dig deeper. Get past any cosmetics someone may have done to hide past damage.
    Good luck brother, I understand staying in paygrade, prior USN E6.
  • With your background, checking out the mechanical areas should not be a problem.
    I found one link with a little info...and it has a link to a safari group on yahoo that might help. Look in the 5th post.
    Thread about safari
    Hopefully, Wolfe10 will see your post and join in. He has a lot of knowledge about the Safari coach.
    As already posted, very important to look for water (leak) damage. Easily the most destructive force to attack an rv ouside of a wreck.
    Good luck.
    Fred
  • If there is mold, mildew, rotten wood, anything like that. Walk away there are rigs that are sound.
    No 'deal" is good enough for a beginer to have to rebuild the rig.
